[GRASS-dev] i.rotate in Add-ons, philosophy for the region increase before processing
Glynn Clements
glynn at gclements.plus.com
Thu Nov 22 11:40:54 PST 2012
Yann Chemin wrote:
> Could you please give me your advice:
> i.rotate in add-ons will need to have some space around the image before
> rotating it, then it should actually write to disk that enlarged (and
> rotated) raster data.
> In the GRASS GIS manual, it says that it is not recommended to play with
> window sizes once you opened a raster (
> http://grass.osgeo.org/programming7/gislib.html#Region).
> Should it be telling the user to select a region large enough before
> running it?
> Should there be an exception for a module (i.e. playing around with region
> settings within module)?
> Any other option?
Not changing the region after opening a raster is an implementation
constraint. It doesn't constrain how a module behaves. You just need
to set the window before opening the raster (you don't need to open a
raster in order to obtain its "cellhd").
In the case of something like i.rotate, it shouldn't force the user to
rotate the entire image, as they might only need a portion of it.
Instead, it should provide an option to enlarge the region to fit the
rotated image.
Also, regarding i.rotate specifically:
1. At a minimum, it should support any affine transformation, not just
rotation. Possibly even projective and/or polynomial transformations.
2. The rotation origin should be able to be specified by the user.
3. It's working the wrong way around; the output coordinates should be
projected to the input coordinate system, to ensure that there aren't
any gaps.
4. It should support interpolation methods other than
nearest-neighbour.
5. It shouldn't require loading the entire raster into memory.
The easiest way to get most of these features would be to take the
code from r.proj.
