[GRASS-dev] r.stream.extract - grass7-addon
Helmut Kudrnovsky
hellik at web.de
Fri Nov 23 06:13:32 PST 2012
hi,
I've tried following command:
r.stream.extract elevation=srtemgea accumulation=srtemgea threshold=100
stream_rast=r stream_vect=v direction=f
and following warning/error arises:
ERROR: Missing value for parameter <d8cut>
the manual says:
d8cut=float
Use SFD above this threshold
If accumulation is larger than d8cut, SFD is used instead of MFD.
Applies only if no accumulation map is given.
Default: infinity
but accumulation map is given in the command.
any idea?
System Info
GRASS version: 7.0.svn
GRASS SVN Revision: 53972
GIS Library Revision: 52468 (2012-07-27)
GDAL/OGR: 1.9.2
PROJ.4: 4.8.0
GEOS: 3.3.5
SQLite: 3.7.10
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-stream-extract-grass7-addon-tp5018389.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
