[GRASS-dev] r.stream.extract - grass7-addon
Markus Metz markus.metz.giswork at gmail.com
Fri Nov 23 07:44:00 PST 2012
On Fri, Nov 23, 2012 at 3:13 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi,
> I've tried following command:
> r.stream.extract elevation=srtemgea accumulation=srtemgea threshold=100
> stream_rast=r stream_vect=v direction=f
> and following warning/error arises:
> ERROR: Missing value for parameter <d8cut>
> the manual says:
> d8cut=float
>     Use SFD above this threshold
>     If accumulation is larger than d8cut, SFD is used instead of MFD.
> Applies only if no accumulation map is given.
>     Default: infinity
> but accumulation map is given in the command.
> any idea?
I could not reproduce this, but I guess that the parser changed
somehow. The d8cut option of r.stream.extract is adjusted in r53993,
please test.
Markus M
> System Info
> GRASS version: 7.0.svn
> GRASS SVN Revision: 53972
> GIS Library Revision: 52468 (2012-07-27)
> GDAL/OGR: 1.9.2
> PROJ.4: 4.8.0
> GEOS: 3.3.5
> SQLite: 3.7.10
> Python: 2.7.2
> wxPython: 2.8.12.1
> Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.n6.nabble.com/r-stream-extract-grass7-addon-tp5018389.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
