[GRASS-dev] 3D points in grass7
Helena Mitasova hmitaso at ncsu.edu
Fri Nov 30 10:56:40 PST 2012
when I need to display 3D vector points as 3D points (not draped over a surface), is this supposed to happen automatically
when I switch off the display on surface button or it is not supported yet?
I get that the vector map is 3D but there is no button to tell it that the points should be displayed using their z-coordinate.
maybe I am missing something?
Thank you, Helena
