[GRASS-dev] 3D points in grass7
Anna Kratochvílová kratochanna at gmail.com
Fri Nov 30 11:54:16 PST 2012
On Fri, Nov 30, 2012 at 7:56 PM, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> when I need to display 3D vector points as 3D points (not draped over a surface), is this supposed to happen automatically
> when I switch off the display on surface button or it is not supported yet?
> I get that the vector map is 3D but there is no button to tell it that the points should be displayed using their z-coordinate.
> maybe I am missing something?
Currently, 3D points should be drawn with z coordinate by default. The
'display on surface' is misleading, now you can't drape them over any
surface.
This option is present in the library, so it must be added to the gui.
I will try to look at it later.
Anna
> Thank you, Helena
