[GRASS-dev] [GRASS GIS] #1753: Distance analysis
GRASS GIS trac at osgeo.org
Tue Oct 2 00:28:52 PDT 2012
 Reporter:  scorpionlegend92  |       Owner:  grass-dev@…
     Type:  task              |      Status:  new
 Priority:  blocker           |   Milestone:  6.4.3
Component:  Database          |     Version:  6.4.2
 Keywords:  Distance          |    Platform:  MSWindows 7
      Cpu:  x86-64            |
 I have to make distance analysis in Grass software. Can anyone provide  me
 help in this regard how to use these command.; if possible, can anyone
 contact me and give me a demo on how to execute the task.
 My main objective of using Grass GIS is to determine the minimum distance
 between one layer coordinates with other layer coordinates. I only have to
 display minimum/closest links in the form of line between two layers.
 Also,when grass displays the line, where does it store the information of
 distance between the coordinates that are represented
  by the line.
 Hope to have a quick response from your end.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1753>
