[GRASS-dev] datums not recognized by g.proj?
Markus Neteler
neteler at osgeo.org
Tue Oct 2 01:31:00 PDT 2012
Hallo Paul,
On Mon, Oct 1, 2012 at 11:44 PM, Paul Kelly
<paul-grass at stjohnspoint.co.uk> wrote:
> I have just committed r53297 to trunk, which adds a new datum= option to
> g.proj, which does something very similar to this. If a GRASS datum code is
> given for the datum= option, it will override any datum in the input
> co-ordinate system (or add one if it is missing).
> You can also do
> g.proj datum=list
> to get a list of all supported datums like g.setproj does, but in a more
> easily parseable format similar to the output from datumtrans=-1.
> Hope that helps a bit.
I am very grateful to you for this improvement, especially since you had
to come back to us :)
Thanks much, Paul!
Markus
