[GRASS-dev] need update to core.create_location
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Oct 3 06:06:20 PDT 2012
Hi Michael,
Michael Barton wrote:
> Thanks for the information Paul. This is a good tip to know for command-line typing. It is unfortunate, however, that this undocumented call was used in the Python scripting library. I agree with you that using "datum" for datums makes enormous sense. So hopefully we can get all straightened out.
> I'll wait to do any committing until 1) you give me the goahead that you've fixed the issue in g.proj you mention and 2) I hear from Markus about updating create_location.
I've fixed the issue with g.proj now in r53305. It will now always
update the ellipsoid when overriding the datum. Hopefully that should be
all you need.
Paul
