[GRASS-dev] [GRASS GIS] #1744: v.out.ascii: export all columns
trac at osgeo.org
Thu Oct 4 12:03:34 PDT 2012
Reporter: lucadelu | Owner: martinl
Type: enhancement | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.out.ascii, columns | Platform: All
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:9 martinl]:
> Replying to [comment:8 mmetz]:
> > @Martin, r53278 and r53315:
> > I know you don't want to test your own changes, but you could at least
fix obvious compile warnings introduced by changes to be submitted...
> sorry, I just overlooked this issue. Nobody is perfect ;-)
Sure. But you changed the this particular line of the old code for no
reason, thus introducing a bug, that change caused the only compiler
warning in lib/vector/Vlib/ascii.c which was after quick inspection
justified, and testing that existing functionality is not broken took me
seconds.
> But it doesn't mean that I don't *want* to test my own changes...
But you nearly never do...
Trying to convince you that investing a couple of seconds for testing is
not that bad an idea ;-)
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1744#comment:10>
