[GRASS-dev] [GRASS GIS] #1744: v.out.ascii: export all columns
GRASS GIS trac at osgeo.org
Thu Oct 4 12:08:05 PDT 2012
 Reporter:  lucadelu              |       Owner:  martinl
     Type:  enhancement           |      Status:  assigned
 Priority:  normal                |   Milestone:  7.0.0
Component:  Vector                |     Version:  svn-trunk
 Keywords:  v.out.ascii, columns  |    Platform:  All
      Cpu:  Unspecified           |
Comment(by martinl):
 Replying to [comment:10 mmetz]:
 > > > @Martin, r53278 and r53315:
 > > > I know you don't want to test your own changes, but you could at
 least fix obvious compile warnings introduced by changes to be
 submitted...
 > > sorry, I just overlooked this issue. Nobody is perfect ;-)
 > Sure. But you changed the this particular line of the old code for no
 reason, thus introducing a bug, that change caused the only compiler
 warning in lib/vector/Vlib/ascii.c which was after quick inspection
 justified, and testing that existing functionality is not broken took me
 seconds.
 well, sometimes everyone can do the mistake...
 > > But it doesn't mean that I don't *want* to test my own changes...
 > But you nearly never do...
 huh ;-) I can hardly comment it...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1744#comment:11>
