[GRASS-dev] [GRASS GIS] #1756: V.Distance Command Problem
trac at osgeo.org
Fri Oct 5 06:15:22 PDT 2012
Reporter: scorpionlegend92 | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.3
Component: Default | Version: 6.4.2
Resolution: duplicate | Keywords: v.distance, attribute of nearest feature
Platform: MSWindows 7 | Cpu: Unspecified
Comment(by mmetz):
Replying to [comment:3 mlennert]:
> Replying to [comment:2 mmetz]:
> > Replying to [comment:1 mlennert]:
> > > If I'm not mistaken, this is a duplicate of #672.
> > I think this is a different issue. Here, the table given with the
table option already exists, but the module wants to create a new table.
This is why the module fails.
> Where do you see a table that already exists ? The table to be created
is same4. The module complains about a column 'loc_dist' that already
exists which comes from the create table statement where the creation of
that column is asked for twice:
> 'create table same4 (from_cat integer, to_cat integer, loc_dist double
precision, loc_dist double precision )'
Right, I mixed up different bugs, sorry for the confusion! I have applied
your patch from #672 to devbr6 and relbr64 in r53318/9.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1756#comment:4>
