[GRASS-dev] [GRASS GIS] #1756: V.Distance Command Problem
trac at osgeo.org
Mon Oct 8 23:19:41 PDT 2012
Reporter: scorpionlegend92 | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.3
Component: Default | Version: 6.4.2
Resolution: duplicate | Keywords: v.distance, attribute of nearest feature
Platform: MSWindows 7 | Cpu: Unspecified
Comment(by scorpionlegend92):
Is this problem resolved??
This command created problem when I selected this option:
"attribute of nearest feature given by to_column option"
In this case, it does not execute the command and displays the above
mentioned error. I have tried using different names for the columns of
distance output file, but the same problem persist irrespective of the
column name.
When we run v.distance command, it creates a dbf file that contains column
name that we define in the command menu. The problem refers to creation of
dbf file with these column names.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1756#comment:5>
