[GRASS-dev] [GRASS GIS] #1759: Selecting maps in dropdown menu: slider to move up/down maps does not work
trac at osgeo.org
Sat Oct 6 03:47:12 PDT 2012
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-trunk
Keywords: map selection | Platform: Linux
Cpu: x86-64 |
Changes (by annakrat):
* keywords: => map selection
* component: Default => wxGUI
Comment:
Replying to [ticket:1759 pvanbosgeo]:
> When running GRASS (6.4 or 7.0) under Ubuntu (11.10 and 12.04), the
slider to move up/down in the dropdown list of maps does not work. It does
appear (see attached screenshot), but when clicking on it it disappears.
Could you try the widget in wxpython demo (download
[http://downloads.sourceforge.net/wxpython/wxPython-demo-2.8.12.1.tar.bz2
here]), it's the ComboCtrl widget, look for TreeCtrl popup. If it works
for you, there is some problem in the wxGUI code. For me (Ubuntu 10.04) it
works fine.
> It is also not possible to move down or up the list with maps using the
keyboard arrow (should that be a feature request?). Thus, the only two
ways to select maps is by scrolling using the mouse wheel, or, when one
wants to select one map only, typing in the first letter(s) of the map
name.
Related ticket #1251
Ticket URL: <http://trac.osgeo.org/grass/ticket/1759#comment:1>
