[GRASS-dev] [GRASS GIS] #1759: Selecting maps in dropdown menu: slider to move up/down maps does not work
Paulo van Breugel p.vanbreugel at gmail.com
Sat Oct 6 04:05:28 PDT 2012
The TreeCtrl demo works. I can move up and down the folders with both the
up and down keyboard key and the mouse (see screenshot for latter).
Ubuntu 10.04 does not have the Unity interface yet I believe. My assumption
was the problem is related to this. However, as said, the TreeCtrl demo
works.
Maybe the following information is of use? GRASS is compiled with Python
2.7.3 and wxPython 2.8.12.1 (the demo package is Python 2.8 I see). I have
compiled GRASS (both 6.4.3 and 7.0 from source, Python and wxPython are the
default installs on Ubuntu 12.04)
Cheers
Paulo
> not work
>  Reporter:  pvanbosgeo     |       Owner:  grass-dev@…
>      Type:  defect         |      Status:  new
>  Priority:  major          |   Milestone:  6.4.3
> Component:  wxGUI          |     Version:  svn-trunk
>  Keywords:  map selection  |    Platform:  Linux
>       Cpu:  x86-64         |
> Changes (by annakrat):
>   * keywords:  => map selection
>   * component:  Default => wxGUI
> Comment:
>  Replying to [ticket:1759 pvanbosgeo]:
>  > When running GRASS (6.4 or 7.0) under Ubuntu (11.10 and 12.04), the
>  slider to move up/down in the dropdown list of maps does not work. It does
>  appear (see attached screenshot), but when clicking on it it disappears.
>  Could you try the widget in wxpython demo (download
>  [http://downloads.sourceforge.net/wxpython/wxPython-demo-2.8.12.1.tar.bz2
>  here]), it's the ComboCtrl widget, look for TreeCtrl popup. If it works
>  for you, there is some problem in the wxGUI code. For me (Ubuntu 10.04) it
>  works fine.
>  > It is also not possible to move down or up the list with maps using the
>  keyboard arrow (should that be a feature request?). Thus, the only two
>  ways to select maps is by scrolling using the mouse wheel, or, when one
>  wants to select one map only, typing in the first letter(s) of the map
>  name.
>  Related ticket #1251
> Ticket URL: <http://trac.osgeo.org/grass/ticket/1759#comment:1>
> GRASS GIS <http://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121006/7f4b0819/attachment.html>
