[GRASS-dev] [GRASS GIS] #1758: Disabling python support does not prevent entry into python directories during build
trac at osgeo.org
Sat Oct 6 15:41:52 PDT 2012
during build
Reporter: brook | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: critical | Milestone: 6.4.3
Component: Python | Version: 6.4.2
Resolution: | Keywords:
Platform: All | Cpu: Unspecified
Changes (by glynn):
* status: closed => reopened
* resolution: fixed =>
Comment:
Replying to [ticket:1758 brook]:
> The configure option --without-python is presumably supposed to disable
all python support.
Incorrect. It's supposed to disable building C/C++ components which link
against the Python library (are there any of these left in 6.x?).
> However, the Makefiles are set to unconditionally enter the gui/wxpython
and lib/python subdirectories.
This is correct.
> As a result, this option results in a failed build.
Error message? Other symptoms?
> The solution is to conditionally include those directories in the list
of subdirectories for make. Two patches against the 6.4.2 release that
fix this are attached. This has been compile-checked on a NetBSD system
both with and without the --without-python option.
> Presumably this should be pulled up to the more recent versions as well.
It shouldn't go into any version; r53326 and r53327 are in error. If the
build fails due to a missing Python interpreter, the Makefiles should be
fixed so that such errors are reported and ignored, rather than aborting
the build.
A couple of things which stand out are the menustrings.py rule in
gui/wxpython/Makefile, as well as the rule which runs create__init__.py.
The former is decidedly non-critical (it just means that "make -C locale
pot" won't get the strings from the XML files for the menus). The latter
should ideally be fixed to not require Python; the wxGUI should should
only require Python on the target system, not on the build system.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1758#comment:2>
