[GRASS-dev] [GRASS GIS] #1760: Cannot query vector network nodes
GRASS GIS trac at osgeo.org
Mon Oct 8 09:35:58 PDT 2012
 Reporter:  cmbarton       |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  major          |   Milestone:  6.4.3
Component:  Vector         |     Version:  unspecified
 Keywords:  query, vector  |    Platform:  Unspecified
      Cpu:  Unspecified    |
Comment(by cmbarton):
 The wxGUI query issue is already known and reported.
 For v.net, GRASS should be treating node creation like it treats arc
 creation. If the operation is "connect", then the attribute table of the
 input points map should be copied and connected to the nodes layer; if the
 operation is "nodes" than at least a minimal table with the cat value in
 it should be created so that node values can be added later by the user.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1760#comment:4>
