[GRASS-dev] [GRASS GIS] #1761: v.net.steiner broken
trac at osgeo.org
Wed Oct 10 11:12:44 PDT 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.net.steiner | Platform: All
Cpu: All |
Changes (by mmetz):
* priority: critical => minor
* platform: Unspecified => All
* version: unspecified => svn-trunk
* milestone: 6.4.3 => 7.0.0
* type: defect => enhancement
* cpu: Unspecified => All
Comment:
The Steiner tree problem [0] is NP-hard and a heuristic algorithm is used
in this module so the result may be suboptimal. The implemented algorithm
needs quite a lot of memory in order to determine a good (not necessarily
optimal) solution. This is not a bug but inherent to the algorithm used by
the module. There may be less memory-intensive solutions. Changing type to
enhancement.
[0] http://en.wikipedia.org/wiki/Steiner_tree_problem
Ticket URL: <http://trac.osgeo.org/grass/ticket/1761#comment:2>
