[GRASS-dev] [GRASS GIS] #1761: v.net.steiner broken
trac at osgeo.org
Wed Oct 10 12:31:16 PDT 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.net.steiner | Platform: All
Cpu: All |
Changes (by cmbarton):
* type: enhancement => defect
Comment:
Replying to [comment:2 mmetz]:
> The Steiner tree problem [0] is NP-hard and a heuristic algorithm is
used in this module so the result may be suboptimal. The implemented
algorithm needs quite a lot of memory in order to determine a good (not
necessarily optimal) solution. This is not a bug but inherent to the
algorithm used by the module. There may be less memory-intensive
solutions. Changing type to enhancement.
> [0] http://en.wikipedia.org/wiki/Steiner_tree_problem
In GRASS 7, it simply doesn't do anything. No message. Nothing. It
finishes with no output. That is a problem. In GRASS 6.4.3 it generates a
memory error. These are clearly errors. If there is not enough memory,
then it should simply give that as a message, not generate error messages
or fail silently. So at least this needs to be fixed. I'm leaving this at
minor, even though it will probably fail for many uses and users won't
know why. But I'm changing this back to a defect because it needs to fail
in a more graceful and informative manner at a minimum.
I have 8GB RAM and sufficient disk space, and this fails on the
streets_wake map with 3 nodes. it seems like a serious problem if it
cannot handle this limited real-world network with the resources I have.
Some suggestion in the docs to a realistic limit in the size of the
network this can handle would be helpful until the algorithm can be better
optimized.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1761#comment:3>
