[GRASS-dev] vector network questions
Helena Mitasova hmitaso at ncsu.edu
Wed Oct 10 12:12:01 PDT 2012
Markus, Michael
I have the new streets data for wake ready, updated based on 2011 data - I will post the location for grass7 with the new streets later today,
you can try it out, if there are still problems there are some other versions that I can try,
Helena
Helena Mitasova
Associate Professor
Department of Marine, Earth, and Atmospheric Sciences
2800 Faucette Drive, Rm. 1125 Jordan Hall
North Carolina State University
Raleigh, NC 27695-8208
hmitaso at ncsu.edu
"All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
On Oct 10, 2012, at 3:04 PM, Markus Metz wrote:
> First of all, thanks for using GRASS network analysis tools in a
> course, Michael!
> I have updated the manual for v.net, explaining the different
> operation options in some more detail.
> I have updated the manuals of many of the v.net.* modules last year,
> testing and if necessary fixing bugs in the v.net.* modules.
> Apparently, my updates to the manuals were not sufficient for you. You
> object to the use of stdin pipes | which AFAICT work on Linux, Mac,
> and Windows. We can update the manuals to not use stdin pipes such
> that the creation of a text file in your favourite text editor is
> suggested first, then use this file as input for the modules affected.
> An IMHO more serious issue for GRASS 7 is the need to change the
> manuals to use examples from the North Carolina sample dataset, not
> from the spearfish dataset. But using e.g. streets_wake from the North
> Carolina sample dataset can cause out-of-memory errors in some v.net.*
> modules, for which there is no easy fix. The vector map roadsmajor is
> OTOH too simple to demonstrate GRASS vector network capabilities. We
> would need something like roadsmajor for all of North Carolina.
> Markus M
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
