[GRASS-dev] working on a add on to calculate MESS
Paulo van Breugel p.vanbreugel at gmail.com
Tue Oct 16 05:15:40 PDT 2012
HI,
Hi Martin, thanks for the info. Only reason it is in grass 7 is because
that is what I use (I find it works better for me than grass64). I can move
it to grass 6, I probably need to make one or two small changes first
(separator tag).
Although I appreciate that the preferred language is Python, is it in the
plans to make it possible to install shell extensions using g.extension
later on? For me, I unfortunately I don't know Python, and although I would
love to work in Python, I simply do not have the time at the moment :-(
Cheers,
Paulo
On Tue, Oct 16, 2012 at 1:37 PM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2012/10/16 Paulo van Breugel <p.vanbreugel at gmail.com>:
> > Thanks, I just uploaded the r.mess script to the
> grass-addons/grass7/raster.
> > Any feedback is most welcome (adherence to grass and bash scripts coding
> > standards is probably one of the thing to check as I am completely new to
> > this).
> please bear in mind that your scripts cannot be currently installed in
> GRASS 7 via g.extension. Building system of GRASS 7 doesn't support
> Shell scripts [1]. Your script really requires GRASS 7? If not,
> probably you should move your script to addons/grass6. Preferable
> scripting language for GRASS 7 is Python not Bash.
> Martin
> [1] http://grass.osgeo.org/addons/grass7/logs/r.mess.log
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121016/d4563bb5/attachment.html>
