[GRASS-dev] images2gif.py in grass
Luca Delucchi lucadeluge at gmail.com
Tue Oct 16 06:41:24 PDT 2012
2012/10/16 Margherita Di Leo <dileomargherita at gmail.com>:
> Ahoj Anna,
Hi
> As far as I can undestand, the BSD license is not fully compatible with GPL
> unless it is either the New BSD License/Modified BSD License or the
> Simplified BSD License/FreeBSD License, which have been verified as GPL
> compatible by FSF [1]. Maybe you could consider to use ImageMagik instead,
> which is released under Apache 2 license, which seems compatible with GPL3
> [3].
> Anyhow I'm not an expert and maybe someone may correct me if I'm wrong.
Yes you are wrong... Your first link answer the question, "New"  BSD
is compatible with GPL, Anna you can use images2gif.py
> Thanks,
> madi
> [1] http://en.wikipedia.org/wiki/BSD_licenses
> [2] http://www.imagemagick.org/script/license.php
> [3] http://www.apache.org/licenses/GPL-compatibility.html
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
