[GRASS-dev] images2gif.py in grass
Margherita Di Leo
dileomargherita at gmail.com
Tue Oct 16 06:46:16 PDT 2012
Hi Luca
On Tue, Oct 16, 2012 at 3:41 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> 2012/10/16 Margherita Di Leo <dileomargherita at gmail.com>:
> > Ahoj Anna,
> Hi
> > As far as I can undestand, the BSD license is not fully compatible with
> GPL
> > unless it is either the New BSD License/Modified BSD License or the
> > Simplified BSD License/FreeBSD License, which have been verified as GPL
> > compatible by FSF [1]. Maybe you could consider to use ImageMagik
> instead,
> > which is released under Apache 2 license, which seems compatible with
> GPL3
> > [3].
> > Anyhow I'm not an expert and maybe someone may correct me if I'm wrong.
> Yes you are wrong...
Yes you are right and I'm happy to be wrong, I completely missed the (new)
.. :D
> Your first link answer the question, "New" BSD
> is compatible with GPL, Anna you can use images2gif.py
> > Thanks,
> > madi
> > [1] http://en.wikipedia.org/wiki/BSD_licenses
> > [2] http://www.imagemagick.org/script/license.php
> > [3] http://www.apache.org/licenses/GPL-compatibility.html
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Forest Resources and Climate
I-21020 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121016/50a84a5f/attachment.html>
