[GRASS-dev] images2gif.py in grass
Sören Gebbert
soerengebbert at googlemail.com
Tue Oct 16 06:42:48 PDT 2012
Hi Anna,
i would prefer to convert the images in a "real" video format to avoid
the limitations of GIF.
Maybe you could try to use PyMedia[1],[2] (well, its pretty old) or
utilize mencoder[3] to create the videos?
[1] http://pymedia.org
[2] http://pymedia.org/tut/src/make_video.py.html
[3] mencoder 'mf://*.png' -mf type=png:fps=10 -ovc lavc -lavcopts
vcodec=wmv2 -oac copy -o animation.avi
Best regards
Soeren
2012/10/16 Anna Kratochvílová <kratochanna at gmail.com>:
> Hi,
> I'm currently developing new tool for animation (wxpython-based
> replacement of wxwidgets-based xganim, coming soon to addons) and I
> would like to include the possibility to export the animation not only
> as a sequence of images. It seems to me that the easiest possibility
> is to use script images2gif.py [1] for creating animated gif, which is
> under BSD license. Would it be possible to have it in grass?
> Thanks,
> Anna
> [1] http://visvis.googlecode.com/hg/vvmovie/images2gif.py
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
