[GRASS-dev] [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken
trac at osgeo.org
Wed Oct 17 17:22:38 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: critical | Milestone: 6.4.3
Component: Projections/Datums | Version: svn-releasebranch64
Resolution: | Keywords: location wizard, g.proj
Platform: All | Cpu: All
Changes (by pkelly):
* status: closed => reopened
* resolution: fixed =>
Comment:
As far as I can see this problem still exists; the long-standing bug in
the location wizard was completely separate from this more recently-
arising issue which was due to changes in the way GDAL processes EPSG
projection definitions.
As I see it, working around this is a more long-term project; if nothing
changes in GDAL and it continues to force its own choice of datum
transform parameters, then we will have to see about changing the way
g.proj treats co-ordinate systems generated by GDAL. Possibly by adding
yet another flag, to ignore any datum transformation parameters in the
input co-ordinate system.
But I think we should leave things to settle down a bit before looking at
that.
Paul
Ticket URL: <http://trac.osgeo.org/grass/ticket/1452#comment:34>
