[GRASS-dev] [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken
trac at osgeo.org
Thu Oct 18 01:14:12 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: critical | Milestone: 6.4.3
Component: Projections/Datums | Version: svn-releasebranch64
Resolution: | Keywords: location wizard, g.proj
Platform: All | Cpu: All
Comment(by mlennert):
Replying to [comment:34 pkelly]:
> As far as I can see this problem still exists; the long-standing bug in
the location wizard was completely separate from this more recently-
arising issue which was due to changes in the way GDAL processes EPSG
projection definitions.
But wasn't this just an issue with proj 4.7.1, which was solved in 4.8.0 ?
So, AFAIU, the bug is resolved by the changes in proj.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1452#comment:35>
