[GRASS-dev] [GRASS GIS] #1692: calling a script within a script failing on Windows XP
GRASS GIS trac at osgeo.org
Thu Oct 18 03:39:55 PDT 2012
 Reporter:  hamish                                   |       Owner:  martinl
     Type:  defect                                   |      Status:  assigned
 Priority:  blocker                                  |   Milestone:  6.4.3
Component:  Shell Scripts                            |     Version:  6.4.2
 Keywords:  v.random.cover, wingrass, shell scripts  |    Platform:  MSWindows XP
      Cpu:  x86-32                                   |
Comment(by hellik):
 Replying to [comment:7 martinl]:
 I hope that it was fixed in r53428 in G65. Please could you try the next
 snapshot, at least `v.random.cover` seems to work for me.
 tested here
 System Info
 GRASS version: 6.5.svn
 GRASS SVN Revision: 53456
 GIS Library Revision: 50936 (2012-02-25)
 GDAL/OGR: unknown
 Python: 2.7.2
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1
 v.random.cover --verbose cover=fields at PERMANENT cat=63
 output=random_NP_cover n=500 raster=landcover.30m at PERMANENT
 C:\Users\XXXX\AppData\Roaming\GRASS6\addons/v.random.co
 ver: line 158: v.report: command not found
 ERROR: v.report failed
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1692#comment:9>
