[GRASS-dev] [GRASS GIS] #1692: calling a script within a script failing on Windows XP
trac at osgeo.org
Thu Oct 18 04:57:12 PDT 2012
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: blocker | Milestone: 6.4.3
Component: Shell Scripts | Version: 6.4.2
Keywords: v.random.cover, wingrass, shell scripts | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by martinl):
Replying to [comment:9 hellik]:
> v.random.cover --verbose cover=fields at PERMANENT cat=63
output=random_NP_cover n=500 raster=landcover.30m at PERMANENT
> C:\Users\XXXX\AppData\Roaming\GRASS6\addons/v.random.co
> ver: line 158: v.report: command not found
> ERROR: v.report failed
strange, tested with the same revision (both native and OSGeo4W)
1. `v.random.cover` reinstalled using wxGUI Extension Manager
1. the module runs without problems
Later I will try another Windows machine...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1692#comment:10>
