[GRASS-dev] [GRASS-SVN] r53518 - grass/trunk/lib/temporal/lib
Martin Landa
landa.martin at gmail.com
Sun Oct 21 09:49:05 PDT 2012
2012/10/21 Anna Kratochvílová <kratochanna at gmail.com>:
> Default TGIS driver / database set to:
> driver: sqlite
> database: $GISDBASE/$LOCATION_NAME/PERMANENT/tgis.db
> this is G_important_message and comes from
> lib/temporal/t.connect/main.c. As I understand it, you get it only for
> the first time when the temporal database is created so it should stay
> there.
probably it should be done when user runs any t.* for the first time.
Otherwise it's not necessary and for some users can be confusing.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
