[GRASS-dev] [GRASS-SVN] r53518 - grass/trunk/lib/temporal/lib
Anna Kratochvílová kratochanna at gmail.com
Sun Oct 21 09:59:27 PDT 2012
On Sun, Oct 21, 2012 at 6:49 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2012/10/21 Anna Kratochvílová <kratochanna at gmail.com>:
>> Default TGIS driver / database set to:
>> driver: sqlite
>> database: $GISDBASE/$LOCATION_NAME/PERMANENT/tgis.db
>> this is G_important_message and comes from
>> lib/temporal/t.connect/main.c. As I understand it, you get it only for
>> the first time when the temporal database is created so it should stay
>> there.
> probably it should be done when user runs any t.* for the first time.
I think, this is the implemented behaviour, maybe Soeren can explain it better.
Anna
> Otherwise it's not necessary and for some users can be confusing.
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
