[GRASS-dev] [GRASS-SVN] r53518 - grass/trunk/lib/temporal/lib
Vaclav Petras
wenzeslaus at gmail.com
Sun Oct 21 10:20:34 PDT 2012
On 21 October 2012 18:59, Anna Kratochvílová <kratochanna at gmail.com> wrote:
> On Sun, Oct 21, 2012 at 6:49 PM, Martin Landa <landa.martin at gmail.com> wrote:
>> Hi,
>> 2012/10/21 Anna Kratochvílová <kratochanna at gmail.com>:
>>> Default TGIS driver / database set to:
>>> driver: sqlite
>>> database: $GISDBASE/$LOCATION_NAME/PERMANENT/tgis.db
>>> this is G_important_message and comes from
>>> lib/temporal/t.connect/main.c. As I understand it, you get it only for
>>> the first time when the temporal database is created so it should stay
>>> there.
>> probably it should be done when user runs any t.* for the first time.
> I think, this is the implemented behaviour, maybe Soeren can explain it better.
I thought this too but I just got the "Create temporal database"
message when I was _not_ using any temporal module. (Unfortunately,
I'm not sure what I was doing, maybe just starting grass, gui, ...?)
> Anna
>> Otherwise it's not necessary and for some users can be confusing.
>> Martin
>> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
