[GRASS-dev] G6.4: gui/wxpython/Makefile issue
Glynn Clements
glynn at gclements.plus.com
Thu Oct 25 14:56:59 PDT 2012
Markus Neteler wrote:
> on some platforms there is an error issues when compiling /gui/wxpython/
> the first time. At the second attempt it passes.
> There must be a dependency issue in the Makefile which I cannot identify:
> http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/gui/wxpython/Makefile
> It fails with make -j2 (or higher) as well.
> Any idea?
It would help if you could post the actual error message(s).
