[GRASS-dev] G6.4: gui/wxpython/Makefile issue
Martin Landa
landa.martin at gmail.com
Thu Oct 25 15:04:20 PDT 2012
2012/10/25 Glynn Clements <glynn at gclements.plus.com>:
>> It fails with make -j2 (or higher) as well.
>> Any idea?
> It would help if you could post the actual error message(s).
> http://lists.osgeo.org/mailman/listinfo/grass-dev
it fails when creating menustrings.py, because of missing grass.scrips
dependency. This dependency seems to be missing also in trunk.
GISRC=/home/martin/src/grass64_release/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc64
GISBASE=/home/martin/src/grass64_release/dist.x86_64-unknown-linux-gnu
PATH="/home/martin/sr
c/grass64_release/dist.x86_64-unknown-linux-gnu/bin:$PATH"
PYTHONPATH="" LD_LIBRARY_PATH="/home/martin/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin:/home/martin/src/grass64_rel
ease/dist.x86_64-unknown-linux-gnu/lib::" LC_ALL=C python
core/menudata.py > menustrings.py
File "core/menudata.py", line 218, in <module>
from lmgr.menudata import ManagerData
File "/home/martin/src/grass64_release/dist.x86_64-unknown-linux-gnu/etc/wxpython/lmgr/menudata.py",
line 35, in <module>
from core.globalvar import ETCWXDIR
File "/home/martin/src/grass64_release/dist.x86_64-unknown-linux-gnu/etc/wxpython/core/globalvar.py",
line 28, in <module>
from core.debug import Debug
File "/home/martin/src/grass64_release/dist.x86_64-unknown-linux-gnu/etc/wxpython/core/debug.py",
line 25, in <module>
import grass.script as grass
ImportError: No module named grass.script
make[2]: *** [menustrings.py] Error 1
make[2]: Leaving directory `/home/martin/src/grass64_release/gui/wxpython'
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
