[GRASS-dev] G6.4: gui/wxpython/Makefile issue
Glynn Clements
glynn at gclements.plus.com
Fri Oct 26 06:33:07 PDT 2012
Martin Landa wrote:
> > It would help if you could post the actual error message(s).
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> it fails when creating menustrings.py, because of missing grass.scrips
> dependency. This dependency seems to be missing also in trunk.
The grass.script module should be created by lib/python (PYTHONPATH
must be set correctly in order for Python to find it).
> PYTHONPATH=""
PYTHONPATH doesn't appear to be getting set correctly.
Ah; r42916 (6.5) and r45933 (6.4) back-ported the run_grass definition
(in Rules.make) without the mkpath definition which it requires.
This was fixed for 6.5 by r49620[1], but no such fix was applied to
6.4.
[1] The GRASS_PYTHONPATH setting added in that change isn't used for
anything.
Again, I suggest that any failure building menustrings.py should be
ignored, e.g.:
-default: $(DSTFILES) menustrings.py
+default: $(DSTFILES)
+ -$(MAKE) menustrings.py
$(MAKE) parsubdirs
menustrings.py is only required to get the strings into the .pot file
used for translation. In fact, the rule to build it could reasonably
be moved to locale/Makefile, where it can be made a dependency of the
"pot" target.
