[GRASS-dev] G6.4: gui/wxpython/Makefile issue
Glynn Clements
glynn at gclements.plus.com
Fri Oct 26 06:34:47 PDT 2012
Martin Landa wrote:
> > from core.debug import Debug
> > File "/home/martin/src/grass64_release/dist.x86_64-unknown-linux-gnu/etc/wxpython/core/debug.py",
> > line 25, in <module>
> > import grass.script as grass
> > ImportError: No module named grass.script
> as workaround this ImportError is now catched (see r53555).
That's the wrong fix. grass.script should always be available.
