[GRASS-dev] [GRASS GIS] #1774: color selection for d.vect.chart does not work
trac at osgeo.org
Mon Oct 29 21:37:00 PDT 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: d.vect.chart | Platform: Unspecified
Cpu: Unspecified |
In the GUI for d.vect.chart, it says that multiple colors can be selected
and users are presented with a graphic color selection dialog. This is a
serious problem with control of the module if you cannot select colors in
the graph.
BUT this does not select any colors that are actually used by
d.vect.chart. The module uses default colors whatever you pick. This is a
probably a GUI issue, not a problem with the underlying d.vect.chart
module
Again, this may also affect 6.4.3.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1774>
