[GRASS-dev] [GRASS GIS] #1774: color selection for d.vect.chart only affects first data column (was: color selection for d.vect.chart does not work)
GRASS GIS trac at osgeo.org
Mon Oct 29 21:44:21 PDT 2012
 Reporter:  cmbarton      |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  major         |   Milestone:  6.4.3
Component:  wxGUI         |     Version:  svn-trunk
 Keywords:  d.vect.chart  |    Platform:  Unspecified
      Cpu:  Unspecified   |
Changes (by cmbarton):
  * milestone:  7.0.0 => 6.4.3
Comment:
 This does affect 6.4.3. The color you pick affects the first color of the
 data series but none of the others.
 Previously, you needed to specify colors with RGB triplets, but you could
 specify colors for all data columns displayed. Now that is no longer
 possible.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1774#comment:1>
