[GRASS-dev] why is r.li.setup unavailable in GRASS 7?
Luca Delucchi
lucadeluge at gmail.com
Tue Oct 30 07:42:05 PDT 2012
Il giorno 30/ott/2012 09:44, "Markus Neteler" <neteler at osgeo.org> ha
scritto:
> On Tue, Oct 30, 2012 at 6:38 AM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> > Why is r.li.setup unavailable in GRASS 7? It is greyed out in the menu
and
> > cannot be launched from the command line. Without this, you cannot use
the
> > other r.li modules. But I also see tickets that indicate r.li.setup has
been
> > happening very recently.
> The code is still here:
> http://trac.osgeo.org/grass/browser/sandbox/lucadelu/r.li.setup.py
> and requires testing before being migrated to trunk.
Yes, to test you can call directly "python r.li.setup.py " from the
directory where you downloaded the file.
I worked on it last week and I compared the resulting setup files of python
and tcl/tk and they are identical.
Right now not all the functionality of tcl/tk are implemented, but I'd like
to move it from sandbox to trunk...
> Markus
Cheers
Luca
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121030/c6900ae7/attachment.html>
