[GRASS-dev] r.modis in GRASS 7 trunk
Helena Mitasova
hmitaso at ncsu.edu
Tue Oct 30 13:55:36 PDT 2012
I agree with Glynn and Ben,
when working with students on 50+ different projects it is really great to have everything
in one package and not to worry about which additional tool to install and whether it will work with the latest release.
We used to have the code split into core, alpha and several other groups and it was pain to maintain,
I think it works much better now and the toolbox concept should be implemented at the GUI level.
Maybe PSC should have some mechanism to decide on which add-ons to move to trunk based on a defined set of criteria.
Helena
On Oct 30, 2012, at 12:53 PM, Glynn Clements wrote:
> Martin Landa wrote:
>>> as a regular user of MODIS, I would like to call other MODIS users to
>>> express interest to include r.modis into GRASS 7 SVN.
>> we cannot extend number of modules in trunk forever. Probably some
>> modules should be reviewed and moved to addons.
> Why?
> Keeping modules in trunk ensures that any breakage resulting from
> changes to APIs or to the build system will be noticed. Also, the
> module will be included in the linkage database created by
> tools/sql.sh, and in any recursive grep of the source tree.
> Personally, I'd rather see most "normal" add-ons moved into trunk.
> OTOH, v.in.dwg should be moved to add-ons unless LibreDWG support is
> expected in the foreseeable future.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
