[GRASS-dev] [GRASS GIS] #1777: reference to 6.4.2 in
GRASS GIS trac at osgeo.org
Tue Oct 30 15:06:48 PDT 2012
 Reporter:  jeir       |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  6.4.3
Component:  Database   |     Version:  6.4.3 RCs
 Keywords:  ogr        |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
 Testing GRASS 6.4.3RC1 on Mac OS X 10.7.5
 binaries from cmbarton 24 Oct (GRASS-6.4.3RC1.pkg.zip), installed all
 frameworks
 Issued these lines in a python script
     infile = 'filename.csv'
     grass.run_command("db.in.ogr", dsn=infile, output = 'faults_db')
 made sure file 'filename.csv' is in place and OK
 gives this error:
 ERROR 1: dlopen(/Library/Application
 Support/GDAL/1.9/PlugIns/ogr_GRASS.dylib, 1): Library not loaded:
 /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.6.4.2.dylib
   Referenced from: /Library/Application
 ERROR: Input table <filename.csv> not found or not readable
 Seems that the old 6.4.2 is referenced in libgrass_gis.6.4.2.dylib
Ticket URL: <http://trac.osgeo.org/grass/ticket/1777>
