[GRASS-dev] r.modis in GRASS 7 trunk
Yann Chemin yann.chemin at gmail.com
Tue Oct 30 21:58:29 PDT 2012
On 31 October 2012 02:25, Helena Mitasova <hmitaso at ncsu.edu> wrote:
> I agree with Glynn and Ben,
> when working with students on 50+ different projects it is really great to
> have everything
> in one package and not to worry about which additional tool to install and
> whether it will work with the latest release.
Same conclusion here for teaching...
> We used to have the code split into core, alpha and several other groups
> and it was pain to maintain,
> I think it works much better now and the toolbox concept should be
> implemented at the GUI level.
+1
> Maybe PSC should have some mechanism to decide on which add-ons to move to
> trunk based on a defined set of criteria.
+1
Yann
> Helena
> On Oct 30, 2012, at 12:53 PM, Glynn Clements wrote:
> > Martin Landa wrote:
> >>> as a regular user of MODIS, I would like to call other MODIS users to
> >>> express interest to include r.modis into GRASS 7 SVN.
> >> we cannot extend number of modules in trunk forever. Probably some
> >> modules should be reviewed and moved to addons.
> > Why?
> > Keeping modules in trunk ensures that any breakage resulting from
> > changes to APIs or to the build system will be noticed. Also, the
> > module will be included in the linkage database created by
> > tools/sql.sh, and in any recursive grep of the source tree.
> > Personally, I'd rather see most "normal" add-ons moved into trunk.
> > OTOH, v.in.dwg should be moved to add-ons unless LibreDWG support is
> > expected in the foreseeable future.
> > Glynn Clements <glynn at gclements.plus.com>
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
Yann Chemin
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121031/d99e19f9/attachment.html>
