[GRASS-dev] installing r.modis fails
Luca Delucchi lucadeluge at gmail.com
Wed Oct 31 03:41:26 PDT 2012
2012/10/31 Paulo van Breugel <p.vanbreugel at gmail.com>:
> Hi, I am trying to install r.modis using g.extension, which gives me the
> error messages below. Note that the first three svn warnings also showed up
> during compiling GRASS (reported here:
> http://trac.osgeo.org/grass/ticket/1776) and with any extension I install.
> So they are probably not related to the problem with installing r.modis
> Fetching <r.modis> from GRASS-Addons SVN (be patient)...
> svn: warning: cannot set LC_CTYPE locale
> svn: warning: environment variable LC_CTYPE is en_US
> svn: warning: please check that your locale name is correct
> Compiling...
> ERROR: modis library not imported
> make[1]: *** [r.modis.download.tmp.html] Error 1
> ERROR: rmodislib library not imported
> make[1]: *** [r.modis.import.tmp.html] Error 1
> Installing...
> /usr/bin/install: cannot stat
> `/home/paulo/Data/GRASSdb/latlon/PERMANENT/.tmp/paulo-HP-Z60
> 0-Workstation/5191.0/r.modis/docs/html/r.modis.download.html
> ': No such file or directory
> make[1]: *** [install] Error 1
> 0-Workstation/5191.0/r.modis/docs/html/r.modis.import.html':
> ERROR: Unable to read manual page: [Errno 2] No such file or directory:
> '/home/paulo/.grass7/addons/docs/html/r.modis.html'
so, here there is a problem related to r.modis libraries, I should use
'pass' in a try  exceptions but I don't like so much because if the
libraries are missing no errors are returned during running
> I seems r.modis is installed, but running the command r.modis.download gives
> me the warning message:
> Unable to fetch interface description for command 'r.modis.download'.
> Details:
> GRASS_INFO_ERROR(5384,1): modis library not imported
> GRASS_INFO_END(5384,1)
this seem related to your ticket, and this is related to your locale situation.
I added a request to that ticket
> Best regards,
> Paulo
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
