[GRASS-dev] build error against GCC 4.7
    Glynn Clements
    glynn at gclements.plus.com
    Fri Sep  7 04:15:59 PDT 2012
Angelos Tzotsos wrote:
> After applying the patch, I now get this failure:
> /home/abuild/rpmbuild/BUILD/grass-6.4.2/dist.x86_64-unknown-linux-gnu/include/grass/iostream/minmaxheap.h:747:5:
> note: declarations in dependent base 'BasicMinMaxHeap<keyvalue<int> >'
> are not found by unqualified lookup
> note: use 'this->insert' instead
> Perhaps this was fixed in another step?
Yes, r51633.
