[GRASS-dev] build error against GCC 4.7
Angelos Tzotsos
gcpp.kalxas at gmail.com
Fri Sep 7 12:26:48 PDT 2012
On 09/07/2012 02:15 PM, Glynn Clements wrote:
> Angelos Tzotsos wrote:
>> After applying the patch, I now get this failure:
>> /home/abuild/rpmbuild/BUILD/grass-6.4.2/dist.x86_64-unknown-linux-gnu/include/grass/iostream/minmaxheap.h:747:5:
>> note: declarations in dependent base 'BasicMinMaxHeap<keyvalue<int> >'
>> are not found by unqualified lookup
>> note: use 'this->insert' instead
>> Perhaps this was fixed in another step?
> Yes, r51633.
Thanks Glynn, I already used the latest svn snapshot for 6.4.3 to build
and works fine.
Regards,
Angelos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
