[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
GRASS GIS trac at osgeo.org
Mon Sep 10 15:04:09 PDT 2012
 Reporter:  antonioall  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.3
Component:  Vector      |     Version:  svn-trunk
 Keywords:  v.in.lines  |    Platform:  MSWindows 7
      Cpu:  x86-64      |
Comment(by hamish):
 AFAICT everything in 6.x is quoted,
 L108 reads:
       tr "$fs" ' ' < "$GIS_OPT_INPUT" > "$TEMPFILE"
 your test data works for me on Windows XP 32bit using 6.4.2 with the data
 file stored in 'C:\Documents and Settings\...', even from the wxGUI with
 file selected using the open file browser and without adding any
 additional quoting (so bug #1447 was not a problem)
 you put the version as trunk but the milestone at 6.4.3. Which version of
 grass did you see this in?
 Hamish
 (trac still logs me out every bloody time I comment on a ticket! argh)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:3>
