[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
GRASS GIS trac at osgeo.org
Mon Sep 10 15:08:36 PDT 2012
 Reporter:  antonioall  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.3
Component:  Vector      |     Version:  svn-trunk
 Keywords:  v.in.lines  |    Platform:  MSWindows 7
      Cpu:  x86-64      |
Comment(by hamish):
 > (Mon Sep 10 10:44:48 2012) Comando terminato (0 sec)
 maybe the path contains a UTF8 char?
 the module (the error looks like it comes from 6.x version of the script)
 should edit with an error if it couldn't create the temp file.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:4>
