[GRASS-dev] Grass SVN in Android, display issue
Chemin, Yann (IWMI)
Y.Chemin at cgiar.org
Thu Sep 20 02:26:55 PDT 2012
Tested in Ubuntu 12.04 64 bit
SVN compiles well all the way
________________________________________
From: grass-dev-bounces at lists.osgeo.org [grass-dev-bounces at lists.osgeo.org] on behalf of Glynn Clements [glynn at gclements.plus.com]
Sent: Wednesday, September 19, 2012 7:52 PM
To: GRASS developers list
Subject: Re: [GRASS-dev] Grass SVN in Android, display issue
Glynn Clements wrote:
> Currently, the configure script shouldn't abort if it can't find the
> XDR functions. If you remove the AC_MSG_ERROR, you need to add XDRLIB=
> so that it's always defined.
That should have said "... should abort if ...".
> > So, a high percentage of the GRASS modules do compile now (186
> > compiled, 34 fail, most of them due to the G3D lib XDR issue).
> I'll look into the G3D XDR issue.
Can someone test the attached patch? Not necessarily on Android; the
first priority is ensuring that it doesn't break anything on existing
platforms.
