[GRASS-dev] Grass SVN in Android, display issue
Glynn Clements
glynn at gclements.plus.com
Thu Sep 20 13:55:16 PDT 2012
Chemin, Yann (IWMI) wrote:
> Tested in Ubuntu 12.04 64 bit
> SVN compiles well all the way
I know that it compiles. The question is whether it works, i.e. can
read and write the existing 3D grid format correctly.
Markus has confirmed that reading works (although we need to test all
of int, float, double), but we also need to check that grids written
with the new code can be read (using both the old and new code).
