[GRASS-dev] Grass SVN in Android, display issue
Sören Gebbert
soerengebbert at googlemail.com
Thu Sep 20 14:37:13 PDT 2012
I am testing it.
So far the raster3d test suite runs fine as well as the module tests for
r3.cross.rast, r3.out.vtk, r3.mapcalc and r3.univar.
More tests are needed, but I think it can be committed since it looks
pretty stable. I did not detected any memory leaks yet with valgrind.
Best regards
Soeren
Am 20.09.2012 22:55 schrieb "Glynn Clements" <glynn at gclements.plus.com>:
> Chemin, Yann (IWMI) wrote:
> > Tested in Ubuntu 12.04 64 bit
> > SVN compiles well all the way
> I know that it compiles. The question is whether it works, i.e. can
> read and write the existing 3D grid format correctly.
> Markus has confirmed that reading works (although we need to test all
> of int, float, double), but we also need to check that grids written
> with the new code can be read (using both the old and new code).
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120920/07fd93c9/attachment.html>
