[GRASS-dev] [GRASS GIS] #1742: WXGUI layer manager window doesn't show all menubar entries
GRASS GIS trac at osgeo.org
Sun Sep 23 23:36:26 PDT 2012
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  blocker      |   Milestone:  6.4.3
Component:  wxGUI        |     Version:  svn-releasebranch64
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
Comment(by wenzeslaus):
 Replying to [comment:1 neteler]:
 > (Obvious, sorry) suggestion: autocalculate the width of the window as it
 is already
 > done in some wxGUI windows.
 There is another problem which is connected to this one (probably obvious
 too). If you make Layer Manager window bigger (manually as a user or
 programmatically) on small monitors there will be not enough space to have
 Layer Manger and Map Display side by side unless you will make Map Display
 thinner (but then it will be not useful). I can see only one solution for
 that: One big window for layer manager's and map display's widgets
 ([http://grass.osgeo.org/wiki/GRASS_SoC_Ideas_2012#wxGUI GSoC ideas,
 wxGUI, point 3]).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1742#comment:2>
