[GRASS-dev] [GRASS GIS] #1013: Wxpython - vector georectification fails at i.group
GRASS GIS trac at osgeo.org
Wed Apr 3 05:12:32 PDT 2013
 Reporter:  rchirgwin  |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  6.4.3
Component:  Imagery    |     Version:  6.4.2
 Keywords:  i.group    |    Platform:  All
      Cpu:  All        |
Comment(by harrikoo):
 Yes, it seems that the georectifier runs v.transform in the end, thus
 leaving the "rectified" map to the current location and mapset, not to the
 target location as one is made to expect. It is easy to move the new
 vector map directory to the desired lcation/mapset/vecto -directory.
 All in all, the rectifier as it is in 6.4.2 is not useable; but it does
 contain working parts, and these could be used to implement a working
 solution.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1013#comment:7>
